Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
In recent talks off-forum as well as ones here I have been asked why some things, like lawn mower blades, are bad for knives if they can be hardened enough to get sharp.
First, hard is not exclusively a part of sharp. Everything from paper, to tin foil, to wood, to steel, to glass can be sharp enough to cut you. How many times in a row it can do that is another thing.
"Hard" is relative. It is also only one of many things that makes a knife blade good or bad. The things that need balance are hardness, toughness, brittleness, and wear resistance. I'm not going to go into the details about these, but they are why one metal is better than another for specific tasks.
When a steel with .84% carbon is hardened, all the carbon gets locked in the iron matrix, hopefully making martensite. There is no excess carbon left. Think of this as mortar cement in a perfect blend ( Portland/sand/water). Strong and reasonably hard, it makes excellent knives. Steel in this range is called eutectoid, and takes a very fine edge. it has reasonable wear resistance. Toughness is balanced by the tempering point.
When steel with more than .84% carbon hardens, the excess carbon combines with other things available, and forms other carbides...chromium, manganese, vanadium, tungsten, etc. these carbides are hard balls. Think of this as concrete, strong mortar with stones added to make it even more wear resistant. The size and type of the stones determines the roughness and wear resistance. Steel in this range is called hyper-eutectoid, and make very hard and tough knives. The edge can be fine or more coarse, depending on the size of the carbides. the harder the carbide type, the more wear resistant. Larger carbides may be dislodged from the matrix easier than smaller ones, so even though they may be harder, large carbides make for a shorter edge life.
Now, when the steel has less than .84% carbon, the iron eats up the carbon to make as much martensite as it can, and the rest of the iron remains as ferrite and similar iron structures, and unbounded alloy ingredients. This means that even though the steel got harder, it has little wear resistance due to all the soft stuff the harder martensite is in. This is like cement made with too much sand. The Portland cement combines with as much sand as it can, but there is still lots of unbounded sand in the mix. It will seem hard, but have very low strength. These steels are called hypo-eutectoid, and are tough, but have low edge life and wear resistance. Chromium is often added to toughen the steel up a bit.
When the carbon gets below .45% there just isn't enough martensite to overcome the weaker gaps in the matrix, and the steel will not become hard enough to be usable at all. This makes for a very tough steel, because it doesn't get hard enough to become brittle. These are called low-carbon steel or structural steel. It is excellent for construction of things that need strength and will not receive wear....like bridges and building frames. It is lousy for knives........ regardless of how much alloying is added.
This is where lawn mower blade steel generally falls. With all things done to the max, it still will not harden near what a eutectoid steel will...and won't work well as a knife.
I hope this simplified explanation helps newer smiths ( and a few older ones who swear by their low carbon blades) understand the reasoning behind the recommendation against using mystery and low carbon steel like mower blades.
Lets keep discussion pleasant and educational, as good discourse is how we learn best.
