Nothing too remarkable if your knife has good blade geometry.
Very cool. I never thought to try something that large (we were indoctrinated not to ever deface a book, but it's a good test!). I tried it and my Opinel's and my Mora will slice through a corner of a 330pg paperback, but only if I rock the blade a little and use pressure. My OKC and Spyderco will do it, but only if I saw the blade back and forth. I was out of corners, but the Buck 119 sliced 4 inches into the side of the book with only a single slow forward stroke and downward pressure. Never knew I could do that. The Opinel did best of the bunch, as usual. I may become a fanboy at this rate.
Is that top one a Mora BTW? I don't know knives all that well yet. it looks similar, to mine, but not exactly alike. What's interesting about the Mora is that it seems to take a very sharp and fine edge, but the blade itself is quite thick, so it doesn't slice as well as the Opinels, in my opinion. The point is very sharp though, and you have to be careful not to prick yourself or you will bleed easily. I also like that the blade is full thickness almost right to the point, so it would be hard to break off anything except the last 3/8th inch or so.
