4-6 will normally give you a good working edge.I have some 4 micron coming this week. I'll see how it works out.
If you were to pick only one diamond emulsion for stropping what micron size would you select?
1 micron is a great one-and-done, if you just want one grit.
This ^Too fine and all you do is polish your scratches, not remove them. 1 micron is the finest diamond I have seen do anything, finer and I see no difference under a microscope. I find 1 micron diamond to be a big jump from a 5 micron resin bond diamond stone, I think 2 micron might be a better step, but haven't confirmed it yet. Of course what you are stropping with, and how free of contamination it is, is probably a bigger deal than the exact size of your diamond compound. Then there are the variables of using other abrasives. The rabbit hole is endless.
