What oil for maintanance
Hi all,
I just wondering what oil u folks use for maintanance on your knives.
I don't have any special knife oil, so i'm wondering what I can use.. Maybe any advice or tips?
Greetings from Holland
For my pivots on my folders I use fishing reel oil. Nice and light, works well for me.
Mineral oil. It's food safe, cheap, and it's what Victorinox uses on their stuff from the factory. Very fine and lasts well.
I use Norton honing oil. I use it on my sharpening stones, so I already have a good supply. It is mineral oil, rated as safe for use on food prep knives, and it is less viscous than the laxative version sold in drug stores.
Are you looking for an oil for folding knife pivots or something to protect carbon steel blades from corrosion or both?
I'm looking for an oil to lubricate the pivot. I dont think my blade will rust, I always keep it dry, and try to keep it that way.
Hello fellow Dutchbro,
I prefer using Ballistol. It's nicely available in the Netherlands, foodsafe and cheaper than the branded oils (Victorinox, benchmade). It's great for both lubricating the pivot as well as protecting blades from corrosion. (There are a thousand other uses too).
I would not recommend using WD-40. I've been told that over time, it will attract more dirt/dust and I'm not sure if it is food-safe.
If you're not sure where to get Ballistol, I could tell you a dutch webstore, but I'm not sure if that's against the rules here or not.
Thanks, googled it and it's indeed wide available. I will buy it tomorrow. Bedankt! [emoji51]
I use mineral oil on any knife that could possibly be used for food. On ones that will surely never see food use I'll use flitz, or mpro7 gun oil which also works great
For years knife manufacturers have told people to "oil the joints." I see many knives with worn out tangs from no oil.
Any light oil will work. WD 40 is fine, but if you feel any grinding or loss of smoothness you may need a heavier lube.
I seriously doubt anything you would put on your knife joint will contaminate food enough to hurt you.
Go to the Auto Parts store. Walk up and down the isles until you find something that says Magic on it. Buy it. Poor it in your gas tank and when that doesn't work call us back.
That is a quote from my favorite radio show, that is off the air now alas (rest in peace Tommy), Car Talk with Click and Clack. They used to tell that to people who didn't want to listen to bad news about how much a car repair was going to cost etc.
Not that it applies to you necessarily but I like it.
Is it wise to use wd40?
OK
I’ll bite.
I warn you . . . I’m in a “weird” mood. :cool::eek::confused::p:D:cool: Haven’t had my espresso yet.
WD-40 is good. Does no harm. Really it is about like putting on food safe mineral oil. By the way it stays wet; it doesn’t dry.
I will work the other end of the coin. Why do you want to put ANYTHING on your knife(s) ?
Oil on the pivots is just going to attract pocket grit/fluff.
That is assuming it is going to see a pocket.
although
I live where it is dry (Wild, Wild, West, USA) and I don’t clean fish with my pocket knife.
So
I don’t put anything on my knife pivot or blades.
The exceptions :
  • When I cut rubber items for repair/restoration projects I put regular O’ motor oil all over the blade to allow the blade to slip through the material and not grab and distort the material. Then when I am finished working I wipe it off with a rag.
  • When I get box tape glue/gunk on a blade from cutting packaging I use WD-40 to dissolve the glue off because it is usually the closest thing to hand that works well for that. Then I wipe the blade dry as I can.
Now
I just stumbled across some goop in a Japanese catalog that sells knives and woodworking tools. They had on offer “Camellia” oil that clove oil had been added to. They stated the Cool Guys (Samurai) put that on their swords. I put Camellia oil in parentheses because I think most suppliers these days just sell mineral oil with a fancy label on it. Why do I think this ? Because when I was first using it a decade ago on my woodworking saws it would turn a bit gummy and be a pain to get off before I used the saw. I don’t use it for that reason.
Now it stays wet as if one just put machine or mineral oil on the blade. What has changed ? The way I hold my tongue when I apply it ?
The photos are of my latest knife. I ordered it straight from Japan. I couldn’t find a local supplier that stocked a Japanese double bevel slicer this short.
The reason I post it is . . . it is a good example of what the cool guys think is good to put on a blade that can rust, especially on a voyage across the ocean where it needs max protection, one would assume. What was on it ? Nut’n.
Well no oil anyway.
Note the black magic marker marks near the edge. That was from using my Edge Pro sharpener on ‘er.
Usually I can get the marks off with plane O’ rubbing alc. Not this time. I got to looking at the blade close and it looks like they lacquer coated the blade. Modern Western lacquer no doubt not the real stuff. My theory is the magic marker solvent was just wet enough to combine with the factory coating.
So
no “camellia” from the guys that make the knives
. . . maybe you should get a bottle of clear lacquer ? ? ?
Now this knife has been wet off and on with all sorts of food stuffs since I got it a week ago. All I do is wash it off under the facet and dry it on the dish towel and leave it on the counter to finish air drying.
Absolutely no rust near/at the edge.
The lacquer works anyway.
When the out door temperature gets into the sixties I will probably wash off all this lacquer using fresh lacquer thinner. I prefer the more primitive look of the plain steel with patina on it etc.
Bottom line
at last
if you want some “magic elixir” go with the Camellia with clove.
Real world, at least for me, nothing just wash and dry. Keeps the dust bunnies out of the folders and it isn’t like you are going to get in to high enough cycles of opening and closing that the pivots are going to heat up from the friction.
Finish Line Extreme Fluoro 100% DuPont Teflon Grease, 20g Syringe for pivots - $9.90 on Amazon
and
Yoshihiro 100% Pure Tsubaki oil for blades and wood - $13.49 on Amazon.
WD-40 is good as a solvent to remove dirt, rust and grime but doesn't last long enough for a lubrication and is fairly toxic.
Read the can it is listed as food safe for comercial kitchen use.
I believe I read in an article on the guy who invented it (a failure by the way) it is mostly fish oil.
W means water
D means displacement
40 means the fortieth attempt at a formula that would work.
Regardless of what the can says, it smells toxic which is enough for me to not want to use it on food. You have to ask yourself if you would willingly spray some WD on your tongue..? [emoji38] Prob not but I would with Tsubaki since that is food grade.
Yeah don't eat this stuff [emoji38]
I'm sure there's been worse stuff than wd40 on tongues.
Fish oil? My understanding it's more like aerosoled kerosene.
My experience with wd40 and firearms? Cleans good, minimal lubing, gums up over time.
