I recently put together a "cheapie", large enough to clean up aluminum rims and such.
As suggested, a good light is a must.
My cabinet leaks like a sieve. I'm going to clean it out and seal the seams with silicone, something I knew I should have done during assembly (...
but assembly was a bitch enough by itself!).
It came with a supply of a dozen Mylar sheets with adhesive on the edges to protect the inside of the glass window. I couldn't see fer shit through it, so I said "the hell with that!", and decided I'll be as careful as I can, and when the time comes, I'll just have a new piece of glass cut (
-or buy a new cabinet that doesn't leak.
The next thing I have to do, from experience with an older, smaller cabinet I had, is to get a gizmo for the compressor that filters out the condensation that builds up inside it. I don't know what they're called. Basically it's a filter of some sort with a glass bowl that catches the liquid. I have a small compressor, and I suspect it may be more susceptible to building condensation than a larger one would be. But it sure is a PITA when the blasting media gets clogged up in the hose.
Another important component is a mini shop vac for dust removal and media recovery. In my cabinet there's a hole in the side, about 2.75 inches, with a plastic collar sealed and screwed to it. A shop vac fits nicely on it, but I have installed a screen coffee filter in between, pointing inside the cabinet, which helps to keep most of the media from escaping into the vac.
As air goes in, equal air must come out. Better more vacuum than blowing so as to keep dust out of your way of vision.
And finally, my cheapie was made in China, and I had to order USA made gloves for it because my hands wouldn't fit in the damned gloves provided! (
-And I don't have very big hands.)
I got them on Ebay really cheap.
