- Jan 27, 2021
I want information regarding the sharpening jig clamps for users. If you have not used or tested a jig please do not comment. I am only interested in the jaws/clamp, 2 clamps vs 1 another topics. Why because I am thinking designing my own jig.
Clamping considerations
Models I am currently looking at for jaws/clamp only.
- small knives
- larger knives
- flat ground knives
- distal taper from heel to tip
- easy of use
- does it centre the blade in the clamp or had a habit of tilting to one side etc like my old wicked edge gen 1 does (multiple broken things on it)
- Is the clamp centred in the jig
- Wicked edge Gen 3 cam operated, it appears the jaws close like a pair of pliers hence keeping it centred in the jig, also hinge pins have some play to allow for distal taper.
- TSProf K03 Single/Double Clamp the spring design, allows for taper, two screws for clamp allow for distal taper and flat ground knives with the jacking screw. Downside metal looses springiness and replacements
- Hapstone R2 basically a TSProf clone
- Cone Double Clamps for TSProf K03, its basically the same as the original except the two jacking screws have been replaced by a cone that basically wedges the clamp apart and acts like a jacking screw, downside I see of this is distally tapered knives its going to jack and take load under one side only, not a big issue in my mind.
- Whole Milled Clamps for TSProf K03 (Hapstone also has these) looks like it will only pinch in the centre, simple design but I like more like tweezers you cant adjust the overall gap its set by the solid piece you can only squeeze this closed.
- KME split piece jaw similar to JENDE A 2 piece whole milled Clamp. Purports to deal with full ground and distal taper and remain centred.
