Hello all, throughout the last year or so I have built up a collection of upwards of a dozen knives which are all carried and used. Obviously with daily carry they start to become dull, and I am quite uninterested in sending my knives back for a "spa service" constantly that leads me to be knifeless for over a month at a time. I am looking to get into sharpening my own knives (something I have no experience with), and I do not know what sharpening system I should buy. What's the difference between me spending $300 on a work sharp precision adjust versus upwards of $1,000 on a wicked edge. I would have to assume the main difference in price is the number of sharpening stones that come with each brands system, but I do not know what grit stones I would need. I am sure, like anything else, there are the basics to sharpening and the complicated parts to sharpening but I want to buy something that will allow me to learn and progress when sharpening my knives, for an example I would like to put a basic edge on some of my cheaper knives I consider work knives but I am also very interested in learning how to put mirror edges on my more expensive/fancy knives. Any input from the sharpening pros out there would be very much appreciated! thanks blade forums.
Once the kind gentleman offered to give me a Lansky sharpening system as a gift it reminded me that my grandfather gave me one many moons ago. When I went to retrieve it, I could only find bits and pieces of it in the case which ultimately led me to not buying a sharpener but instead buying another knife. So, in short, I did not begin my "sharpening journey" just yet, although I am pretty sure Santa Clause is going to drop off a work sharp precision adjust for Christmas since many people recommended it as a good place to start.What system did you end up with? How goes the learning curve?
I ended up with a spyderco sharpmaker for now. Got it down good on the kitchen knives, diamond rods necessary, as dull as they were. If time were ever mine, things would be further along. Now if I ever buy a knife with a 15 or 20 degree edge, I'm set. lol
So much to learn.![]()
Here's a helpful little trick that I discovered about using the Sharpmaker: I recommend keeping a small spirit level with your Sharpmaker. The spirit level makes sure that the Sharpmaker base is always sitting on a level surface. If you set it down on a surface that isn't level and you're not paying attention, then it could throw off your angles a little bit. You might be surprised how many flat surfaces that you'd think are level are actually off by a bit, or are slightly uneven in certain spots but fine in other spots.
