- Aug 21, 2014
aebl
Got it. How do these look ? They are all three 7“:
The left and right are a bit above your budget, the middle is within (Excellent Knife). Left to right: 3V, K329 (=A8mod), and INFI.
If toughness and general damage-resistance is the primary quality you're after, then you'd want either INFI or Delta 3V. They are semi-stainless, so they will only rust if you leave them wet overnight. D3V has better edge-holding than INFI, but INFI is easier to hand sharpen in the field. Both are bomb-proof.
Dimension-wise, I like the left and right ones the best. The grey one speaks to me a little more just because I have smaller hands. It looks like it has a hollow-grind too which is nice.
You could do a lot worse than the Buck 124. Don’t be put off by 420 HC steel, Buck does it right. This knife should do everything you require
This statement actually helps a lot.
I don't have a lot of experience with steels other than stainless. In my OP, I linked to the knife steel nerds page on ratings of different steels. I only have experience with stainless (440C, 1.4116, and 420HC), which are all rated around 7.5/10. I have left these knives out overnight and they have been fine. I don't make a habit out of this, but it happens.
Now the rust resistance of the tool steels on that page sit around the 5/10 range. The problem is that I had no idea what 5/10 corrosion resistance looks like. I have no experience with tool steels, so I have no frame of reference of how quickly those steels will rust. Your statement above now gives me that. So basically I'll be okay with a tool steel as long as I'm more mindful of where I'm leaving the knife?
Thin Edge and Tough, and Stainless....?
Your best bet is the NitroV, AEB-L, 14C28N family.
Use what your maker is comfortable with.
You are Canadian?
Then @David Mary ,
Is your man.
He makes many styles in AEB-L that check all your boxes!!!
So with this in mind, which steel should I seek out? I have narrowed down the list to either Magnacut, S30V, S35VN, S45VN, or Vanax?
I suggest you invest in a set of diamond stones as well. Sharpening teaches lots of things about the steels you like and dislike. And the pull through sharpener (if it is one with carbide blades), do yourself a favour and throw it away!Right now, I have a honing steel, a manual pull through sharpener, and a Work Sharp Ken Onion.
This is a good choice but the new Nomad 6.5 seems hard to find these days. Out of stock everywhere. The Nomad 5 inch version is available everywhere and it’s a great knife, I have one. Extremely sharp and well done with a beautiful convex edge. Joker knives are very impressive for the price and the Nomad is the best of the lineI have been eyeing of the joker nomad 6.5 in broler something steel. Which is supposed to be a bit stainlessey.
Bohler N695
