did you make this?I would use Shapton Glass (Al2O3) on the big V. Spritz and go.View attachment 1656684
Sure did. It’s my go to for hand sharpening.did you make this?
Should I go for the 3" wide Arkansas stones? 2" wide ones are a lot easier to find and like 1/4 as expensive....
It would depend on the grit of the diamond compound or spray. The diamond will give a bit more aggression than stropping on bare leather alone.If you strop loaded with a diamond compound as a touch up or as a final step in a sharpening sequence do you loose your toothy edge, and end up with a finer, more polished edge that will dull much easier?
I wonder if you could contact DMT to see if they have (or could custom produce) a 15" diamond plate in your preferred grit?Yes, Arkansas stones are not ideal but I have been using them for over 30 years and am a creature of habit. They can be made to work by keeping them aggressive but you are correct, they are both too hard (insufficiently friable) and too soft (lacking wear resistance) for such a hard and abrasion resistant material. My challenge is finding a CBN or ceramic stone large enough for my technique. I like a 15 inch stone.
The majority of my sharpening process is done on a 3M ceramic belt but a hard stone is necessary at the end to get the edge condition I need. First and foremost there must be no wire edge. I don't care if the damn thing is dull, no wire edge!
