Here are four knives from Cold Steel. All are advertised as having 4-inch blades.
On this paper I've marked two lines, the space between which measures exactly 4 inches.
From left to right: Counter Point I, Large Voyager Vaquero, Recon 1, Broken Skull
As may be seen, only the Large Voyager Vaquero meets the advertised length, measuring 4.00 inches. The rest are either too long or too short.
The Counter-Point I measures a mere 3.73 inches. Comparing them, the blade on this knife is shorter than that on a Spyderco Endura 4, which measured 3.77 inches. This is a large error and the shorter-than-advertised length could irritate many customers.
The Recon 1 is slightly shorter than advertised, at 3.86 inches. The difference is fairly small, so this is not too troublesome.
The Broken Skull is perhaps the worst offender, as the blade easily exceeds the 4-inch mark. It measures about 4.11 inches. This could cause trouble for those in certain jurisdictions.
The blade of the "4-inch" Counter Point I is actually shorter than that on a "3.75-inch" Endura 4
I recently purchased a Cold Steel Pro Lite Tanto. This knife is advertised as having a 3.5-inch blade.
In fact, when I measured it I found the blade length to be approximately 3.26 inches. Another large discrepancy from Cold Steel.
The blade on the Pro Lite Tanto is advertised as 3.5" but measures only 3.26"
Here is the Cold Steel Extra Large Voyager Clip Point. The blade length is advertised as 5.5 inches.
However, when I measured it, I found it to be only 5.31 inches.
The blade on the Extra Large Voyager Clip Point measured 5.31", 0.19" shorter than advertised
Why does Cold Steel seem to dislike providing their advertised blade lengths in increments smaller than one half-inch?
Does Cold Steel not own a ruler?
