thequinox said:
Thanks to your advice I have decided to stay clear of the Zytle and look closer at the aluminum or titanium models. Unfortunately as I stated earlier, except for the EDC, they do not come with a plain edge. How do you guys like semi-serrated? Do you find the serrations get in the way?
P.S. Sorry about all the questions but this is my first knife purchase and I want it to be a good decision. You know how it is.
of course. no need to be sorry, research it fully and get something you like.
as for the combo edge.. ehh, ive always personally preferred plain edge. much easier to sharpen, and you can always adapt a plain edge to the type of cutting you like. contrary to popular belief a plain edge can cut things like tomatoes just as well as a serrated - often better - if you leave the edge coarse (sharpened with a corase stone). the micro-serrations from the sharpening act like tiny serrations and cut very well, through tomatoes, rope, etc. some people hone half of their blade to a fine finish and leave the other half coarse, as a sortof 'combo edge' suitable for different cutting.
i have several combo edged M16s and CRKTs and their cutting performance has kindof grown on me. there are times when the serrated edge comes in very handy (and theyre great for cutting bagels, hehe). honestly the only thing that annoys me about the combo edge on small M16s is this: your plain blade will most likely wear faster than the serrated part, and they become annoying to sharpen. i have a small tanto, and although it is chisel ground so i only have to sharpen one edge its a pain in the ass. as you sharpen the plain edge it will wear lower than the serrated section. so not only do you have to consider the secondary point of the tanto (and sharpen carefully so as not to round it) but now you also have to avoid going too far and sharpening the points off the serrated section which are higher. the small tanto is a small knife (EDK is even smaller) so this is quite a chore to do, and unless you are very patient you will end up sharpening the points off the first few serrations. sharpening an EDC knife is common practice and therefore should not be a difficult procedure, so as a personal preference i wouldnt choose a combo edge or a tanto.
look at the M21-02 and decide wether or not you like the blade shape. a drop point blade with a pronounced belly like that is an excellent cutter. theyre also readily available in plain edge (double ground) and are a breeze to sharpen with just about anything.
chisel ground edges in steels like some of the ones CRKT uses are also a chore to sharpen, because you will tend to roll the edge inadvertantly over to the unground side, merely from the softest pressure on the stone. often i have to very gently hone the unsharpened side to make a tiny bevel in order to get a good edge on these knives (in fact they come from the factory like this - with a tiny bevel on the unground side).
i have some older M16s without the LAWKs back when they were readily available in plain edge, and they are all double ground. suffice to say they are a joy to use and sharpen. it was really a stupid move on their part to switch to only combo edges on the base models of their flagship line. im sure switching to chisel ground saves them a few cents in production as well. im actually considering doing a double grind on my M16-13, possibly even grinding off the serrations, but this is going to cost me some blade width.
if you like CRKT's designs check out the hammond desert cruiser, the special forces model. also a very nice looking knife - only reason i have not bought one yet is that they are only available in combo edge
cheers,
-gabriel
