I know, I know, RR spike knives will never be a real knife, more a kso than anything. However, I have two that I have made as souvenirs for my daughter and cousin. I want them to be as usable as possible so they can be used as more than a paper weight. My daughter is 9 and my cousin is 14, so these won't be hard use knives and may never even be used, but I'd still like that possibility. So, with that, what should I quench them in to get the best results? I have canola oil, straight water, and water from a salt water pool that is 3100ppm of salt (my math is not working good to make that a percentage). I have used motor oil, but know better than to use that.
Also, after hardening, should I temper them? If so, what temp would be good?
I know this is mostly speculation as no one knows what alloy the spikes are made from. However, I'm doing this knowing it's speculation and that I won't get the best results from these knives. Like I said, they are mostly souvenirs, but I'd like them to be as usable as possible too. For a real knife, I'll stick with the 1084 that I have.
All bashing and "you should use known steel" aside, what say you?
