Wool blanket and an axe... If I could bring 2 more it would be... a poncho and a multi tool
I take it you would be hacking down limbs to place under your blanket?
30ish degrees is at or above the melting point, I would have to disagree just a bit because
1. it takes a long time for the snow to melt, and even then most places in Alaska are covered in moss
2. at 30ish degrees it will be easy to build up a sweat, and at the same time very easy to rapidly cool off once you stop working.
So what we're looking at is 30ish degree weather, with wind chill factored in we're looking at a rather humid time of winter where it becomes very easy to sweat and freeze due to the moisture.
for an unknown amount of time, 30.06 rifle with ammo, sure it's overkill for rabbits, squirrels, and fowl, but what we're looking at is the time of year where bears end their hibernation cycle and start looking for food and are usually in a very bad mood.
Alaska has so many lakes and ponds ice fishing may be possible, but is extremely unlikely since most places will have around 3-6 feet of ice.
So fishing is out of the question for food.
Snow will be covering last years berries IF there are any berries to be had at all.
The biggest concern is keeping yourself dry, because dry means warm.
Assuming that you brought all of the best/necessary clothing, meaning layers and material that wicks moisture and the perfect boots that somehow manage to keep dry, is this place in BFE with virgin powder? is there extensive travel involved?
Nothing works like a 'good' pair of snowshoes if you have to walk on snow that isn't drifted, maybe cross country skis which could also be used when you make camp to
CROSS COUNTRY SKIS
1. clear snow 2. be a bench to sit on 3. help form a shelter. 4. knock down branches from trees 5. help build a primitive sled for hauling MEAT or wood!
6. act at a clothes drying rack for your fire.
There are so many possibilities for this open ended question. I think the question needs to be narrowed down to what items you already have, WHERE in Alaska you are going.
(seriously, the state's two and a half times as large as Texas, the zones range from desert to temperate, vast mountain ranges, valleys, rivers, lakes and can be one of the hardest places to survive.)
I hope I'm not being too serious about this, but it is my state.
Simple answer assuming that I get to choose the clothing that I get to wear at the start of this excursion it would be a 30.06 and cross country skis.
My EDC blade doesn't count as extra supplies since it's a given that I have it with me at all times.
