- Jun 7, 2002
seems like a versatile steel. tough enough to use as a slip joint whittler, easy to sharpen and scary sharp when used as a modern EDC folder, strong enough for a 7-inch fixed utility blade.
Moderation in all things, brother. VG-10 is excellent, plain and simple. Does it have the edge retention of "new" super steels? Probably not. It also doesn't have issues with chipping, or difficulty in sharpening. Literally anyone, with a bit of practice and a good sharpening system can put a surgically hair popping edge on it, and can reasonably expect it to hold up very well under typical use. Great steel.
To my experience with larger VG-10 knives like the Fallkniven NL1 and NL2, VG-10 holds an edge very well!All I know is from my own experience and that experience is that my shun 4 inch deba has chipped from butchering chicken when chopping through back bones and whatnot. Nothing major but the next time I cut up a chicken ill bust out the loupe and take some pics.
Fwiw I am sure its a perfectly good steel for folders.
If the edge is too thin for the material being cut it can chip or bend, but this happens to many a good steel when the edge is too thin.
The cure is to set the edge thicker, when sharpening.
Regards
Mikael
It's a great steel. Holds a great edge and is easy to sharpen.
It may not be the sexy steel right now, but there are still lots of good knives using it and I wouldn't hesitate to buy one with it.
I put vg10 in the same league as 440, maybe even just right below it. Sure you can use it, but why would you want to when there are MANY better steels...
Say what now!!??I put vg10 in the same league as 440, maybe even just right below it. Sure you can use it, but why would you want to when there are MANY better steels...
To me VG-10 works more like stainless A2.
As my models are laminated, the outer shell is softer and very tough.
The harder core stands for edgeholding and wear resistance..
Those MANY better steels are seldom availible in the designs I like!
I do buy and use powdersteel knives, but I have yet to find knives like the Northern Light series in powdersteel.
Let's not forget that blade geometry and heat-treatment comes before the steelchoice!
When these parameters are put together in a good design, the result will be awesome.
Even in VG-10.
Regards
Mikael
Its All about the heat Treat and geometry of the blade.
Shun seems to leave their VG-10 knives too hard? I get more chipped up Shun than any other brand with VG-10 steel.
I don't use Shun, but I agree about the importance of heat-treat and geometry.
How do the Shun's perform after You have reprofiled and sharpened them?
Regards
Mikael
