im looking to buy a welder in the future for making hidden tangs. whats a good inexpensive welder to get? is it easy to learn? ive done oxyacetaline back when i was in middle school (about 10 years ago) i welded on angle iron and decorative flat bar. can you link me to the one you are talking about?
The words inexpensive and good seldom are found in the same sentence when discussing welding equipment.
For knifemaking Tig would be the best system. It offers the most control, you can weld any kind of steel, (stainless and tool steels need to be welded with stainless or tool steel wire)
Stick is old school, mostly it's used outside where wind would effect the shielding gas. Stick makes the most and hardest to clean off spatter. Stick is strong but it is the least precise of the three. It is also probably the least expensive for a good unit. No shielding gas needed
so it's less expensive to operate.
Mig is all automatic, The machine does all the thinking. All you need to learn is how far away to hold the gun and how fast to move it. The poster who said it takes 20 minutes to learn was exagerating, It should only take 10 minutes.
Mig requires spooled wire and shielding gas, and a variety of copper components Tips, nozels, gas difusers, and steel liners, all of which wear out perodicaly. If you change wire size you have to change everything from the feed rollers to the tips to use the unit. Mig is probably the most expensive to operate due to all the spares you must buy.
Tig makes the strongest welds because you control the heat and the wire. You can make very small precise welds and not spread heat too much, That means less warping. You might be able to find a small tig unit for a reasonable price. Tig also makes very clean spatter free welds.
Avoid those 110 V. gasless mig units. They use a flux core wire. They all say you can weld 1/4" steel, You don't get even remotely enough penetration to weld 1/4" They are made for automotive body sheet metal. The heaviest steel you should weld with those units is maybe 1/16" to 3/32".
Something else to consider, Fumes. In order from most to least Stick, Mig, Tig. Stick uses flux coated rods, (I'm sure you can imagine) Lots of smoke!
Mig uses steel wire that is electro-plated with a thin copper coat. (To prevent rust and better conduct electricity) Most of this burns off when you weld. It's not good to breathe burnt copper. Less smoke than stick but still substantal.
Tig uses Thorated Tungsten electrodes, You can get non thorated but I don't know how well they work. Thorated tungsten is slightly radioactive. There is a very small amount of erosion of the electrode when you weld so you are probably getting some tungsten in the fumes. But there is almost no smoke or fumes in Tig.
