Strongly advise having something larger than a cup for water/food prep....esp for multiple persons.
Is that Stanley the double-wall INSULATED cup?Not ideal for cooking/boiling at all.
Oh nononononono
Knowing what your local emergency responders will be using will help, FM works better in urban areas, AM for rural, much bigger reach, shortwave for world. If I had to pick one, AM would be my choice. NOAA band is also very handy since you can get weather updates, works in Canada as well, at least enviro canada used the system last time I was there. HAM is another option. Again, depends on what you do, and where you are as to if it will help much or not.
Oh nonononononoIt's the steel one. It came with the two insulated cups though. Good idea though, I will look into getting something larger
....None of the fancy gadgets will teach you your surroundings and they're all useless if you don't have them with you/ can't carry them because the bags to heavy. ....
I'm sure I forgot some items
Pretty heavy loadout to get you only 15 miles primary. First glance tells me you've set forth the bulkiest, heaviest load in the thread, esp. since you said there's even more. But maybe not...
Nothing to cook or boil in? Check my list on Page 1 for some items I think you are lacking, IMO.
Cooking means stopping and making fire which both uses valuable time and draws attention. Name why I would need to cook or boil and I can give you 20 reasons in my environment why I don't. Name one useless item in my bag ( looking for feedback not trying to come across as an a hole).
Me either. Honest.
True. I suppose there are roots, berries, grubs and tubers in abundance out there.
Nothin's useless when the need arises.![]()
you young-uns think you're so smart. what about us guys with less-than perfect 20-20 vision? aside from spare reading glasses, you need sun protectors, a couple of magnifying lenses (for seeing and for starting fires), and maybe two mirrors (one flat, one concave.)
Most likely I would be traveling at night due to working swing shift so heat shouldn't be too bad. For water that's where the Source UTA adapter and silcock key come into play.Rule of 3s right, for 15 miles of hoofing it, yeah, you'll burn some calories, but home is where food is. So that's not a big deal. 15 miles in Vegas summer heat, and water will certainly be a limiting factor, If you are dehydrated when you get home, and there is no easy re-supply there (lets go with multi-state blackout as a pretty plausible bad news scenario) Then suddenly a heap of food does not much matter. Plus some guy busting out a jet-boil in an urban area instead of moving on, that's going to draw attention. Someone with a pack looking like they have a destination in mind, much more invisible.
In my case, anything that leaves me time to bug out, leaves me time to pack both cars and clear out, otherwise everything in the apartment is part of the bug-in plan. Camping fuel, water jugs. anything that means I have to run, I get my man-bag, and thats it. I won't be able to carry enough to make a difference, because it will be a mad dash for high ground. And we'll see how far I can sprint.
I've also got the advantage of 10 years accumulated camping gear, some of it for fun, some for guiding. So I can pick depending on what's coming. I keep coming back to the fact that there is no template.
Echoil, just out of curiosity what's the risk matrix as you see it for where you live, just the generals, what could happen, how likely, and how bad would it be?
.....Echoil, just out of curiosity what's the risk matrix as you see it for where you live, just the generals, what could happen, how likely, and how bad would it be?
