A slightly belated response on my part, but thanks for all the tips guys.
However... I'm still having some trouble with the knife and I'm not sure why. For the sake of clarity, let me give you a detailed description on what exactly I'm doing.
I've probably put like 3 or 4 hours of solid work with the extra course diamond hone on the knife so far. From what you've all said, it seems like I should have a re-profiled and sharp edge by now, although I most assuredly do not. In fact, it's quite dull; so much so that I can apply pressure and run my fingers on the edge and not get cut at all. I've frequently been doing the "magic marker" test and it seems like I should be on the edge, although there might be a very tiny black line at the most terminal edge of the knife (so small that is is hardly visible to the naked eye and I currently have no means of magnification).
When using the extra course hone I am indeed applying a decent amount of pressure. At first I was making small concentric circles on the blade maintaining contact with the steel and the hone the entire time (i.e. both an downward and upward stroke in one motion) as I thought this would be the most efficient way to simply remove material from the edge. As I thought I was getting closer to actually working on the edge, I went to just a downward or upward stroke. I should note that I have absolutely no justification for my technique and have only been following my intuition (which granted may be totally incorrect).
I should note that during the beginning of the re-profiling process, I was not paying very close attention to working each side of the edge equally. I figured that at beginning it didn't matter all that much, although I did approximately try to work each side equally. As of late however, I have been making sure that I do an equal amount of strokes on each side.
As for the clamp, there might be a problem. I know it's very important to have the knife securely locked in position, which for the most part it has been, but every now and then the blade slips and moves maybe a a millimeter away from the original clamped position. I usually catch this pretty quickly and with a little force push the knife back into its original position.
I'm pretty sure that those are all of the potential factors that could be hindering my progress on the knife, but of course, maybe there are others. I'm just flat out confused at this point and a bit frustrated too. Why am I have such terrible luck with this?
