- Apr 16, 2014
Just received my first CAK from hi, what's the best way to care for the handle
I think I speak for all of us when I say that if I woke up tomorrow with lady bits, the first thing I'd do is have an affair with Bawanna.
I've treated my horn hilts with lanolin. It seems to be effective in hydrating them, but it does leave them rather greasy.
Appreciate the help, I'm gonna try to get some hooflex soon, which kami's mark is the fish?
How wide are the cracks snowwolf? If they are still fairly thin, you might be able to fill them with super glue, sand bone into them and then sand everything smooth then apply hoof conditioner with just a faint line showing afterwards. If it is more than a 1/16" or so, you have to either fill them with epoxy colored black (add black tempra powdered paint or get black dye for epoxy) and fill the cracks. Epoxy runs easier when smooth but is hard to work down in the cracks - use a razor or sharp edge to push it down in.
Hoping they are still narrow for you.
I would glue it then put three hose clamps around it while it cures. The clamp at the butcap sometimes slides down but it will eventually grab somewhere between the ring and buttcap. Put some paper under the hose clamps so they dont scratch things up. After it cures release the hose clamps slowly over about a week (if you have the patience). Ill loosen them about a quarter turn each day till they are loose. After a week the glue will be fully cured and you can condition it with hoof stuff or oil and that will soften and relieve the stress so it dont crack in other places. I put a piece of tape along each side of the crack to minimize sanding afterwards and also over the fresh epoxy so that when you squeeze the clamps down the epoxy gets forced inside toward the tang instead of out the crack.
