- Sep 27, 2001
Ok, I've heard a lot about this new Super Stainless Steel CPM S30V, also the S60V & S90V. They are suppose to be the bomb for knife steels. (Then you have INFI, which I'm not totally convinced isn't a trick of heat/cryo treatment.) So, what is the difference between ATS34/154CM and the CPM S-V steels? Are they really that much better? I have noticed that a lot of makers have gone to these steels. Is it because they are new or because they are better?
Now you all probably know I an a tracker knife fan. I have talked to a few different people about steel for a long term survival knife and most say high carbon because of easy of sharpening in the field. Something like 0-1 or D2. They say it's easier to take care of in the field. Now, I'm of the belief that if something doesn't need sharpening it's easier to sharpen just because you need to do it less. Now if ATS34 is harder to run across a stone but you only need to sharpen it once to D2s' 4 sharpenings then I'd rather have ATS34. (Just an example) Now I have a Busse MeanStreet and I use it for everything. I've owned it for 6 years now and carved countless bow drill kits, sharpened spears, split wood, gutted fish, dug holes and cut barbed wire, to name a few. Digging the hole was really the only thing that dulled it, the wire did put a small ding in the edge but it came right out with a few swipes on a fine stone. Point is, I carry my MeanStreet because I've had it all this time and only had to sharpen it may 3 or 4 times and it never took that long because it never gets that dull. So, What is the difference between these two, the ATS34s & the CPM S-Vs? Thanks for your help.
Ric
Ric
