My take on AutoLawks is simple, usually when I am using a knife at work which is my primary hard useage of blades ( i am an auto technician for land rover) but usually my other hand is encumbered. I need to move fast because the faster I do things and accomplish jobs the more money I personally make. The problem with autolawks is that it makes it more difficult to close the knife one handedly. I have also found that the little red/brass switch is uncomfortable on my finger tip. I don't have any issue with the normal LAWKS because then if I am using the blade under hard use, I have the choice to engage extra protection. But over the years I have had many knives with both of the systems, and over time every single one that had autolawks I eventually removed the system entirely. This is simply my opinion based on the way I generally use my knives, and the way you use your knives may vary completely, so for you this could be a very convenient system. But I like to be able to flip it open, perform cutting task, close without thinking and slip back into my pocket.
