What does everyone think of the bubble jig. Good idea for a beginner or no?
Thanks for posting this. This thing is not a sled jig and it is not magic. As you say it takes practice; but the practice is done with a lot more confidence because you are not guessing.+1 for the bubble jig and practice. Be very aware of keeping even steady pressure as you move the blade and don't just start at one and and pull to the other or your plunge will always lag behind the rest significantly. Start a bit out and slide back to your plunge line then reverse the length of the blade. This takes some practice since that one section will progress faster until you get the hang of how fast to move and when.
Sharp belts help tremendously. With dull belts it's hard to work slowly because of how much heat they generate, you have to stop and cool the blade too soon. A nice sharp fresh belt lets you get good results without heavy pressure and without lots of heat, freeing you to focus on the fundamentals.
I'm still very much a newbie here and have trouble getting my bevels and plunges to match side to side, but by following the advice I've gotten here (and lots of practice) I'm very good at keeping them nice and even individually. heheh, it's getting them to line up together that I have issues with. I always goof something on one and then have to fix it, which requires going back to the other side to make them match again.... The remedy is simply more practice.
It certainly helps me a lot. As you say, it's a confidence and "cheat" for getting a consistent approach. I can pick an angle for the thickness of the steel, height of grind, and single or double bevel style and use the bubble to know I'm at the right angle as I work. That doesn't mean I can't mess up, but it DOES give me feedback that I'm messing up. If that bubble starts to stray from center once I've worked my way to the chosen angle (I set it and manually work the bevel upward to that angle rather than change the jig through the steps) then I know I somehow pushed the blade out of position far enough to be off kilter. I can then see WHERE on the blade it is and see my progress back to straight more easily.Thanks for posting this. This thing is not a sled jig and it is not magic. As you say it takes practice; but the practice is done with a lot more confidence because you are not guessing.
Fred
Use a jig. I use a piece of 2" angle steel and clamp the blade to it. Simple, and you can get straight grind lines with ease.
