- Aug 31, 2009
I guess what I meant to ask was- If you had a scandi blade and a convex blade, same steel, same edge angle and thickness at the cutting portion, and you performed the exact same tasks (we'll say feather sticking and power cuts into wood), which blade would dull, chip, roll and need to be touched up more often?
I'm pretty sure scandi is the answer. I just wanted to hear a scandi guy differ.
the Scandi will be thicker behind the edge if you were matching edge angle and spine thickness. (see Marcinek's picture) so theoretically the convex will fail first because it has less material behind the edge.
the problem is that most people are comparing 2mm thin Mora knives, to chunkier "survival"knives with a convex grind.
