- Sep 17, 2007
How else am I supposed to open the boxes that all my knives come in?
^^^ From your description, I'm surprised all of the knives in that photo still have tips on them. Only kidding![]()
I'm sure that this has been covered about 50 times in the past year, but the bottom line is, that the ability to cut boxes and still retain an edge is a tried and true test of any blade.
+1. Mannlicher stated it well too. It's a good test of a blade.
I think dirty cardboard may have sand and other debris embedded that can damage an edge, but I believe the abrasive you are referring to that is in fresh cardboard is clay. This is also what make cardboard effective for stropping things.
For those who prefer using a box cutter on cardboard, I highly recommend the bimetal blades by Lenox. Irwin also makes them. The edge lasts significantly longer than the Stanley blades, plus they won't snap off if bent. Except the very tippy tip, which is 100% the harder edge steel.
Also, utility knife blades CAN be sharpened, although almost no one does it.
I've broken down > 100 boxes in a day before.
I use my knives for anything and everything. Bottle opener, food, boxes, trimming bushes/shrubs, garden work, unwrapping pallets, etc., etc.. I was scraping tape off a mirror with my PM2 yesterday. Basically there's always a knife in my pocket, so I will try to use that before I go find a different tool.
Your are correct. Clay in clean and sand/clay on dirty cardboard. Basically abrasive media that's readily available to test the wearability of steels/edge strengths.
I do not believe I said "Clay is clean", nor did I mean that by intention. Not sure we're you are attempting to go with that.
The 92 of 100 cuts through dirty cardboard can cause an edge to chip, same as the 1st of 100. All it takes is running into a single piece of embedded debris that is barely larger than the width of the apex (tiny rock-chip, piece of glass, etc.) completely skewing any test data a user may be attempting to compare. Testing without baseline media is not much more than playing around. I have seen folks learn this time & time again.
Even new cardboard is known to have occasional embedded debris that can significantly skew test run results. In general many if the principal edge retention reviewers I follow have moved away from cardboard when discussing and performing comparison trials unless they are using the medium as an illustrative as to how badly results can be skewed by contaminated and/or inconsistent media (a number of Cliff's videos and related threads exemplify this as do others).
I do not mean to argue anything here, but to clear up what you "perceived" I wrote.
So, to be clear I do not believe cardboard to be an effective "test" medium for edge retention. I do believe it can be used to strop knives (which is what I wrote in previous post).
Regards,
Large enough sample sizes and correcting for standard deviation should be enough to compensate for poor testing medium.
I agree (if "general idea" presumes to ignore micro-chipping and small damage that many folks ignore or can't see/feel).
Would your care to give the average reader here an example of how many lineal feet of cutting this takes to correct for poor testing medium.
And, how many trials.
Someone should do a test that no one should really ever care about:
Have a third non-vested party break down two identical boxes to identical size pieces.
Do one with a box cutter/utility knife, the other with a mid-priced folder or fixed blade.
See which job is done the fastest, which cutting utensil retains the cleaner edge when done, which one is the most comfortable to use, etc.
Argument solved.
