- Oct 24, 2004
Do you use a steel?
Do you use a strop?
How often?
And how often do you sharpen?
Thanks!
Do you use a strop?
How often?
Thanks!
HoB said:I set the edge at 15 deg each side with #180 stone, work up through #700, and #2500 to #10000 on waterstones and finish with a few strokes on CrO loaded strop. Strop in between whenever it stops shaving effortlessly. If I used it hard and the blade has nicks, I go back to #180, if it is extremely dull, I may go back to #700, if it just needs a touch up that is a bit beyond the capabilities of a strop I start at #2500.
If I am in a hurry or on the road, I use a Sharpmaker according to the recommendations.
I used to use a steel, but have totally gotten away from it. I think the whites on the Sharpmaker work much better under similar conditions. They align + refine, while the steel only aligns. The material removal with the whites is really not an issue.
yuzuha said:In the process, I discovered that, occasionally, there is just something mindlessly relaxing about sitting there doing nothing but polishing a hunk of metal....
HoB said:My favorite stone is the non-paraille blue stone: Great feel, as fast as a much lower grade stone but a finish like a #3000. Must be the combination of the different grits in the stone. Affordable and LARGE!
My #10000 is a Naniwa super. VERY nice feel, but a little delicate. Would love to try a Shapton. I am still eyeing a #5000 shapton, but can not bring my self to part with the money yet, too many knives to buy.
The Ice bear are "just" the regular King stones. IMHO very good stones, but they don't last as long or cut as fast as the more expensive Bester stones.
HoB said:yuzuha: Both the man-made blue and the Naniwa gauge pretty easily, but the Naniwa seems to chip quite easily on the corners and it looks as if it may even get small cracks on the corners due to the wetting and drying (your not supposed to store in in water, as a matter of fact, hidatool recommends against storing the any water stone in water, but I store all but the Naniwa in water).
