I would suggest purchasing both types for grinding steel. You will always need the platen for grinding steel, to may sure all is flat and right.
But if you are planning on hollow grinding your blades out. You will need the wheel to do that. I would not recommend shaping out a knife with the wheel. And the reason is, by utilizing the wheel it would created a rounded radius on your work. The platen is for flat grinding and shaping steel material.
So, if you can afford to purchase both then do so. But if you can not, then go for the platen. You can always get the wheel later on down the road. Hope this was of help to you and look forward in seeing some of your creations. :thumbup:
I HAVE BOTH, I JUST WANT TO KNOW HOW YOU, THY HOG OUT THE BLADE FORM.
ON WHEEL OR PLATEN
THANK FOR YOUR REPLY
VERN
