You might ask sunray-inc.com if they do that sort of thing. They use a urethane rubber rather than vulcanized rubber. Works fine and is a WHOLE LOT cheaper!
I've had good luck turning elastomer on a lathe using a corner of an aluminum cutting geometry endmill. Make of that what you will...
You can do this on your grinder. You drive the wheel with a belt and setup your cutter behind the wheel and upside down (think about it) and feed across with a cross slide table or rotary cross slide. Make of that what you will...
