I want to make some reference lines for etching my name in the blade, but I want the reference lines to be parallel with the guard.... so first things first, I put the guard back on;
Anything that's flat and parallel will work for this. The exact height isn't important, I just want a line to make it easier to position my stencil;
Here's the whole set-up for etching my name into the blade;
The electrolyte and all purpose cleaner that's used with the etcher;
Here's the stencil I'll use on this blade. I have three, but use this one the most;
It really helps me to use back-lighting so that I can position the stencil properly. Since the stencil is dark green, and the blade is dark, it's very hard for me to see where I'm putting it if I just lay it down on the bench;
Here's a close-up.... this is more like the way I see it when positioning the stencil;
Once I get it where I think it's right, I like to look at it upside down. I have no idea what the science is behind this... but if you look at it right side up, you tend to read it just as much as you try to center it. When it's upside down, you just see it as an object rather than a word, so it's easy to see if it's right. For me anyway! LOL;
I actually bought the video for the etcher (15 years ago) and you're supposed to douse the etching hand-pad with electrolyte, then dob it on a paper towel so that it's not soaking wet;
Making contact with the stencil. The machine is set on DC current, and it's actually removing metal through the stencil now;
