- Feb 4, 2009
Op, this is generally a controversial subject especially with the sharpening "masters"
I would suggest you take three or for of the same knife (like a cheap edc knife or one you use every day.) Put a polished edge on one, a "medium" edge on the other; so go to 400 grit and then strop, and a coarse finish on the other; I'm talking use the 120 or 240 and then LIGHTLY strop.
I'm sure you'll be able to draw your own conclusions from that little experiment. Don't forget a control though, use the same knife as it was from the factory.
I say buy 3 or 4 because if you use the same knife, there will be a lot of variables that you will be unable to control.
I've used all of the edge finishes you can imagine and loved a coarse edge for a while. After I had my first truly mirror polished knife, I will only create that type of edge from now on. A proper mirror edge will IN MY EXPERIENCE outlast a coarse edge (no mountain peaks to be ripped off).
Unless you need the microbevel, I say lose it. Like knifenut said, going from 50,000 grit to 1200 grit doesn't make sense; it's just a lot of wasted work. If you want a coarse edge, use the coarse belt. Most factories leave a very coarse edge NIB, so I'm sure you know what one feels like.
Good luck!
Good luck!
