Just apply hand pressure on the back of the blade.
Controlled, and doesn't do stupid wear and tear on the lock for no reason.
Oh, I had a knife that passed spine whacks but failed the hand pressure test; haven't had any that were the other way.
Oh, and don't buy crappy knives; that solves most of the problems right there (the one that failed a hand pressure test was a crappy knife).
Too bad you guys are getting hurt. It all seems to come down to sloppy technique. Stuff that'll get you hurt opening boxes.
Stay safe.
How to avoid knife failure due to a spine whack or unintentional hit in two easy steps:
1 - Buy a framelock.
2- Squeeze the framelock handle in a gorilla grip when you're cutting with the knife thus forcing in the lock bar eliminating any slip or disengagement.
Problem solved LOL.![]()
True dat! I do love me a framelock despite it not being a tri-ad lock lol
Not sure why the condescending attitude, It comes off as you're the only one who knows how to use a knife and because you haven't experienced a lock failure everyone else is doing it wrong.
Any folder I buy, I like to know the lock works. I haven't seen a single proponent of viciously beating on the spine of their knife in this thread. Seems most people are stating their personal experiences and why a gentle testing of lock geometry is a good thing. No need for the high horse routine. That attitude is pretty common around here " It hasn't happened too me, so all of you are fools and doing it wrong" is a pretty close minded mindset in my opinion.
If I mistook your post for condescending I apologize, text doesn't allow for intent to come across so well.
I can't tell if you are in the camp that believes spine whacking is abusive and distorts the locking surfaces or not. If you believe you can bang these parts together hard enough to make some blades fail, but it will have zero effect on others - than I can see your brake analogy.In for the sake of in.
More like testing the brakes.
One does not need to test their own knife to destruction (crash), but there are certainly differences in lock-strength such that a non-destructive test for one design is quite damaging to another design. If you slam the brakes, will your car stop quickly and within a short distance? Or will the brakes fail from the experience?
What is the point of a lock on a knife? What is the point of a spring on a slip-joint? To keep the blade open against closing-forces below a certain level. What is that level? Is it not important to KNOW that level before exposing yourself to injury? Or at least establishing a working range - e.g. well, my lock can withstand X level of closing force and that is more than I should ever need, I don't need to know the maximum.
I'm with chiral.grolim on this one. If there is incremental damage from spine wacking on wood, the bearing surfaces are either too small or not hardened enough...
Interestingly, for the hardening side of the issue, I had an old Spyderco Civilian (aluminium handle) and there was no comparison in the hardness of the lock bar and the hardness of the blade itself (this doesn't seem to be as obvious on the currently made G-10 handle lock bars, which also have a much harder pivot, not a very, very soft pin): I know this because I sawed a slot into the lockbar to put in a piece of copper: I twisted out the copper from the slot, this twisting action firmly "locking" the copper in place inside the slot, and the thin extended end of the copper piece acted as an additional thickness between the blade and lock bar: This subterfuge eliminated any blade rocking for 10 years until I lost the knife...
It was quite easy to saw a tiny slot into the lock bar with a modelling razor saw: There was no way to even mark the blade side with that tiny saw... This, it seems to me, is wrong, as one side being much softer will eventually develop the gap that I had to fill-in with an extra piece... The knife lasted 15 years in total, and thousands of opening cycles, but it started very tight and had to be "adjusted" after only 5 years (it remained tight 10 years after that with the copper piece)...
Gaston
I must lack imagination; that and I watched a movie about how to use tools once.
Well it's too late for me but as for the rest of you kids don't educated. If you do you won't be able to stab oil filters with screwdrivers or pull wild hypothetical scenarios out of your hat.
I'm using this thread as a guide for the "do not buy from" list on the Exchange... I don't want your LNIB spinewhacked folder... :barf:
There are knife fiddlers and knife users. Knife users don't have the time to model their knives with $1000 cameras, and equally expensive lenses and filters, to try and make it look like they use their knives. Only knife fiddlers do.
And knife users sometimes inadvertantly whack the spine. Usually when withdrawing the knife out of a confined space they were cutting something in. And their hands bear the scars of said locks failing.
Nothing wrong with being a knife fiddler. Knife users just don't like it when knife fiddlers, who have manicured hands, tell knife users that lock strength is not important. Knife users make a living with their hands, and heavily stitched hands or digits, means a loss in income.
