- Jun 4, 2010
Everyone always talks about polishing and honing on super fine abrasives... I want to get a really gnarly, toothy edge, the kind that makes slicing through meat or fibrous materials seem like child's play.
I know a few members here have played around with sharpening on lower grits so I don't think this topic should be too esoteric...
The lowest grit I have personally is a 220 JIS waterstone. I've played around with edges fresh off this before... It can be difficult to remove a burr and get it really refined, but I've gotten edges sharp enough to shave my arm hair--if my skin can bare it. So for that reason I've still wound up finishing on a relatively higher grit. Usually 1000 JIS waterstone or 25 micron DMT, and I find myself liking the edges I get from the coarser DMT a little more but that's just for everyday carry kind of stuff.
I think that if I were going to be cutting something with a lot of abrasive qualities
Going to come down to the steel in question up to a point. Some stainless and high RC carbon steels will not hold a coarse edge very well, if they can even take one due to chipping along the apex. My opinion is that waterstones are not a good choice for this either, the coarse ones do a good job of metal removal without making deep gouges or causing pressure bulges behind the apex. These qualities make other options more functional, though it can be done. A hard vitreous stone or diamond works better, and edge leading will make a cleaner grind (by hand anyway). My own experiences led me to believe that going under 80-100 grit is not the best idea, and finishing with anything other than plain paper or paperboard for a strop is likewise not the best idea. Even a relatively coarse grit on a strop will eventually smooth the irregularities.
These are the only types of edge prep where I'll use a microbevel.
Also in my experience these edges incur a substantial penalty when chopping or pressure cutting, so while it makes a wicked draw cutting edge it becomes limiting factor as well, something to keep in mind. If it were for a really bruising repetitive task I'd opt for a softer steel, likely carbon, and use a small file to sharpen it. Once had to do a lot of cutting on some fiberglass "supertuff" insulation board. Used an old kitchen knife, glued some 3M 30 micron polishing film to a cardboard tube. Used the film to touch up (sharpen) the edge and stropped on the tube itself. Two rapid 8 foot cuts through this material and the blade was almost too hot to press against my arm - that's abrasive!
