Yes, they are called shavettes or something. I may try that to save $. I have no problem sharpening anything. But may try the replaceable blade set up to start.Don't they do safety razors with replaceable blades?
I think the idea is if you miss you are less likley to cut your own head off as there is only a sliver of blade sticking out.Yes, they are called shavettes or something. I may try that to save $. I have no problem sharpening anything. But may try the replaceable blade set up to start.
Close but not quite, a shavette will still take a nasty bite, since there is still not a guard, they are just not as heavy as some there is no real blade momentum (that's shockingly a thing when you get to either 6/8 and taller or wedge profile blades, they don't have to be "sharp" they just keep on going) The downside to a shavette is that lack of momentum so they can "feel" duller because every hair cut is transmitted to the fingers and face, think chopper vs paring knife, the chopper may not be "sharper" but it ain't stopping.I think the idea is if you miss you are less likley to cut your own head off as there is only a sliver of blade sticking out.
My advice to you if you are going to learn how to hone straight razors is to not ask for advice on honing in the straight razor forms that are out there.Yes, they are called shavettes or something. I may try that to save $. I have no problem sharpening anything. But may try the replaceable blade set up to start.
I’ve been reading about honing. Everything from using flat stones to stones shaped to mimic a wheel radius to generate a concave edge. Lots of differing information for sureMy advice to you if you are going to learn how to hone straight razors is to not ask for advice on honing in the straight razor forms that are out there.
By now you probably have a razor. For starters I'd suggest going to a barber supply house and get a cheap handle with good disposable blades. You're learning curve can be short.Budget is not a bid issue. Looking to get a good set up and give it a try!
