Yeah I agree. I find mine indispensable for slipjoint making. I've got 3 discs, all flat one knife edged, which I had gotten them all that way although no big deal to fix them.
I had two aluminum discs and hated them.
I wont say I change discs very often on my setup, but I've got 3 discs and could get by with 2, but I do like keeping one course grit (which lasts a lot longer, and then use another for 400ish paper, which you'll be replacing constantly. If you dont already use it, 3m 77 spray adhesive works great. I tried feathering adhesive and found it to be a mess, and a pain in the ass to clean up. Now I keep a piece of cardboard about 3 times as big as a sheet of sandpaper laying near the disc and a can of the 77 spray, lay the paper on the cardboard, quickly spray with 77 from about 10 inches away just coating the paper. Let sit for 10-20 seconds, and then attach to the disc. Has plenty of hold, but will easily peel off when you're done.
Faster than monkeying with the feathering goop and trying to get it evenly spread before it starts getting tacky, once it's been on a disc for a few months it's nearly impossible to remove. 77 spray cleans up with high proof iso-pro or similar and a scotchbrite pad with the disc running slowly and some pressure.
