As much as the lure of building a forge from just a few bricks and a propane plumbers torch sounds attractive, it will still be a minimally effective forge. It will be OK for forging a small blade as long as you pay attention to heating evenly. For HT it is going to be pretty poor in evenness of heat for any blade over 2" in edge length. With no heat control, all you can do is get the blade section to non-magnetic and then heat a little more and quench. What you get is what it is. Holding a 1095 blade at 1450F for ten minutes (soaking) will be impossible.
The cost of a hot burning torch and the bricks, plus the few other supplies needed will cost you around $50.
For about $100 you can build a proper forge that will do forging and heat treatment fairly well for many years to come. The principles of use are the same as the 2-bricker, but the heat control and evenness of the heat will be light years ahead.
Later on, with an additional $100 you can add PID control to read the temperatures in the forge and control them. This will make the forge very good at HT.
