- Jun 28, 2007
Anywhere in between $10-$50 depending on how many knives, and which heat treater you're using. I usually pay per blade and it's normally in between 5-15 depending on the size of the blade.How much generally would it cost if I wanted to send just one knife for heat treating?
Holding something to temp for 10 minutes in a flame is a LOOOOOOONG time. You're not going to have much fun with that. You'll run risks like Overheating, underheating, bending the steel, warping the blade and a few others.I want to work with 1095 steel, and have been doing some research. Would need to make a little furnace out of firebrick, drill out a hole for the tip of a propane torch and another hole for a high temp thermometer, put the knife in there, bring it up to 1475 degrees, or until a magnet no longer sticks to it, hold it there for about 10 minutes, then quench the blade in canola oil brought up to around 150 degrees. Then temper it at 500 degrees for 2 hours, and then I have a finished knife.
Honestly. If you're getting 1095 and you want to get optimal heat treat send it out.
If you don't mind getting just decent but maybe 90% heat treat out of it you can do it yourself.
