- Jun 17, 2006
If the teeth are ground away, and the good steel is gone, what is left is the softer steel, right? So how deep into the blade does the good steel go? Does it stop immediately at the top edge of the teeth, or is there perhaps another 1/16" that is good?
There would have to be some steel below the bottom of the teeth for it to be welded on as a single strip. Otherwise the mfg. would have to individually attach each tooth. If you're thinking of trying this yourself then don't try to mess with a bimetal blade. Get one described as "all hard" or " high speed steel" so you won't need to worry about it. A bimetal or welded edge blade would only be useful for making a santoku or sheepsfoot blade anyway.
I bought a box of 10 all hard M2 power hacksaw blades on eBay 4-5 years ago and ground a very crude Loveless-style blade from one. Talk about tough to grind! M2 at 64-65 hRC really eats through belts.
I used this knife to dress a deer a couple of years ago. The edge retention is amazing! I am careful not to stress the blade laterally, but you know it can't be TOO fragile or the blades would never survive. I imagine the machines that use blades this big aren't exactly used for dainty tasks!
