- Mar 18, 2008
Here's how I would play it with cranks.
1 Standing timber that reaches the surface. Something with a square bill to deflect when running it into the timber.
2 Rip rap dam Non rattling tight wobble fished parallel to the bank
3 Weeds/ Lily pads Tuff one. If the weeds are just below the surface, I would run a wide wobbling noisy shallow crank right over the top. If they're thick weeds I would run the edges of them with a deep diver, also noisy. However in thick weeds or pads I opt for dropping a 12" worm in holes Texas rigged with heavy rattling weight. I've sometimes used up to an ounce of lead. In sparse pads I have had luck using a Storm Hot & Tot with the metal lip. I like the flash and the sharp metal lip can sometimes slice through the thinner stems.
4 Flats I hate flats, so many choices so little time, I usually bypass flats and target structure...
5 Steep banks/bluffs deep diving so that it hits the bottom and deflect off rocks. I would change up between wide and tight wobble as well as noisy and rattle less.
6 Long extended points/humps Definitely a suspending crank and/or jerk bait, and I would play with all depths.
