- Jun 26, 2005
jet higher end delta are great if you need one fast, watch craiglist clausing,delt variable speed,walker-turner are some of the best. spend the money and buy keyless chucks
That will even work with high hardness high alloy stuff. :thumbup: I'll use old carbide ball endmills to cut out busted drills and taps etc. What you're doing is much better than just drilling the hole. However, there are a couple disadvantages compared to using a reamer.
An end mill has relief ground behind the cutting edge, which is what allows it to be fed sideways though material without rubbing. That makes an endmill inherently more "grabby". If you use a four flute, this can lead to chatter. If you use a two flute, there is nothing to prevent "lobe walking" (I just made that term up, but it describes it exactly, motion kinda like a wankel engine) which is the tendency of a two cutting edge tool to cut slightly triangular shaped holes (like a drilled hole). That tendency is minimized with a short stiff carbide cutter, so I'm sure you get good results. But, for a similar cutter cost, you could use a multiflute reamer which will do the same job and is sized more accurately than an endmill. Let me reiterate, there is nothing wrong with your approach, but you might find using a reamer works just as well or better.
Huh?
I'm sorry Jim, but I don't understand what you're talking about. I think you may have misunderstood what I was getting at. Nothing that I was talking about involves the use of counting turns, reading the dials or using a DRO. With the exception of indicating on an existing hole to ream a hardened pivot (where alignment to a fixed workpiece would be important) I'm not talking about anything laborious, time consuming, difficult or fancy here.
I'm talking about using an XY table to speed up and simplify moving a work piece around, that would otherwise be laboriously clamped and tapped about trying to position and clamp to a static table to get your drill bit aligned where you want it. An XY table makes this faster and easier. So you can go hunting or fishing or whatever...
So, no offense, but if all of the work that you're doing on a drill press is unsupported and unfixed (meaning you never clamp or fix something down), you might be missing something.
