- Jun 14, 2006
i have a question. if you were to shrink the edge angle down a bit would you sand some of the crinkle off first or just attack with out mercy with the EP?
Attack :thumbup:
same here with the 100 stones. I go through a stone in about 3 knives with heavy reprofiling.
I tend to keep a bowl of water and a water swuirter next to the table. that way I can squirt off the stone/steel residue and let it drain into the bowl of water.
I usually set mine up in square casserole dish to catch the run off. :thumbup:
thats a good idea...
since I have no where else to post these - heres an example of how to do a fast convex edge with an edge pro:
three bevels, one at 10 degrees, one at 15, and one at 18
heres the 10
the 15
and the 18
after which you just sand out the edges, and you have a nice continuous and repeatably convex edge. this way, you know exactly what your cutting edge bevel is. I didn't want to hijack justabuyers thread, since it was hand sharpening only. I couldn't hand sharpen an edge if my life depended on it
this is a thin modified knife, so its a bit easier and faster to do this. I did something similar on a stirder mt, and it took me literally 24 hours of using 2 100 grit stones to get the main bevels set. it was pretty rediculously thick, and TORTURE to sharpen. the metal just did not want to grind off.
I have the PRO model and it is super solid :thumbup::thumbup: I figured that if I am going to spend that much on a sharpening system I might as well get the best oneI have been happy with it since the day I got it which is probably close to 8 or 9 years.
Can you fit diamond stones to an EdgePro to speed up the reprofiling?
Cubic boron nitride (CBN/Borazon) is recommended instead of diamonds for grinding steels (diamonds burn and dissolve into iron so CBN works better than diamond), but I hardly ever see it in hand or bench stones... only a few touch up tools for tungsten carbide cutters, like these http://www.titantoolsupply.com/tbhh.html
not sure why... maybe because there isn't as much of a heat problem with hand honing? CBN is also harder than things like tungsten, vanadium or silicon carbide so should not have any trouble with high carbide steels either, but I'm curious about the different handling characteristics (a diamond plate should have a different feel and cutting properties to a CBN stone)
I have been involved with the jewelry business for many years. Diamonds are nearly pure carbon. I have seen jewelry grade diamonds heated to over 2000 degrees with no ill effect. In fact, they are often cast in place. Diamonds don't dissolve into iron- they may chip microscopically, but I don't believe you could dissolve one.
Bill
It isn't heating, but the carbon in the steel and the carbon in the diamonds, see for example "Modern Grinding Process Technology" by
Stuart C. Salmon.
"diamond, being a carbon based material, has an affinity for the carbon
in the steel and suffers accelerated wear by the dissolution of the diamond
into the carbon in steel, producing an iron carbide (Fe3C) with most
unsatisfactory results."
-Cliff
