- Aug 15, 2005
Greetings,
I have a Grizzly Mini Mill and it's okay... All of the Mini Mills are apparently made in the same factory in China, so they are all very similar. I would suggest that you get one with a R-8 spindle taper, since the the collets and such seem to be much cheaper than ones for Morse tapers.
The mini mills advertise the fact that they can be tilted at angles, which I have never found to be useful. In fact, it is a hinderence. Several times I have been milling a piece and used a bit too much pressure. The whole upright assembly has jumped out of alignment necessitating clearing the table and re-tramming the mill. What a pain!
If you can afford it (and can move one) I would suggest that you get a slightly larger mill, such as the Grizzly G3358 Mill/Drill. Like the mini mill, there are several places marketing this type of mill and I suspect that they are all made in the same factory. I would get one with a power cross feed if possible.
Here is a link to the Grizzly so that you can see what it looks like;
http://www.grizzly.com/products/item.cfm?itemnumber=G3358
I hope this helps.
-Chris
I hope this helps.
-Chris
