We often talk about which lower grit belts to use for hogging. There isn't much talk about the higher grit belts, such as 320, 400, +...
I have used the Hermes RB 406 J-Flex in 400 from Pops and they seem to work pretty well. I have also used the 400 grit AO belts from Supergrit and they work well, but wear out rather quickly.
What 400 grit belts do you use?
I have never used a grit higher than 400 because it's pretty easy to start hand sanding after that, but what about you? How high of a grit do you go before hand sanding?
