Are there different "grades" of titanium? Don't know much about titanium but g-10 is a bitch to work with.
Here's the numbers. 6-4 Annealed Ti vs G-10 Laminate Sheet (www.matweb.com)
_______________________________Ti_________G10
Tensile strength (MPa)___________830_______262-310
Compressive Strength___________860_________448
Rockwell Hardness______________36C_________110M
Impact strength is harder to compare, since metals and composites are tested differently. If anyone wants to try sorting out the comparison, G10 is about 6-7 J/cm (Izod) and 6-4 Ti is 17 J (Charpy). Given the high elongation at failure of the titanium (10%), I doubt it's going to fracture under real-world knife using conditions.
I don't think they use G10 for machines which are expectd to operate at 1100 degree F, or for high stress structural compents on military aircraft, commerical aircraft and or space craft.
well g10 is plastic titanium is metal i don't really think plastic is better
It is more reasonable to compare CP Ti to G10 rather than a Ti alloy. CP Ti is more likely to be used as a knife handle. 6Al4V Ti is significantly stronger than Chemically Pure Titanium.
Technically, G10 is a composite and not a polymer. The two are actually quite different. Composites are generally stronger, lighter, and more expensive to produce than polymers. Polymers are more often used in cheap injection molded products (such as toys). You will find composites in many places needing high strength with minimum weight such as drive shafts, aerospace, and knives of course. (For knives, I think the main purpose of G10 is actually for grip and environmental resistance without the extra weight. Knives that use G10 often have Titanium or stainless steel liners. I have also seen full tang fixed blades with G10 handles bolted on. Strider and Kiku Matsuda do this for many of their fixed blades.)
If we compare CP Ti (grade 2) with G10 we get:
UTS
Grade 2 Ti : 49.9ksi
G10: 45ksi (longitudinal)
Density
Grade 2 Ti: 4.51g/cc
G10: 1.8g/cc
(data from matweb)
Grade 2 Titanium only has a slight edge on G10 in ultimate tensile strength and G10 has a big advantage over Grade 2 Ti in Specific Strength (strength to density ratio).
I must comment though, that I havn't seen any knife that has CP Grade 2 Ti for a handle material (At least, it doesnt' seem to be advertised). Chris Reeve uses Grade 5 in his Sebenzas and I believe Emerson uses Grade 5 in most of his knives as well. (You will find some Emersons with a stainless steel liner for the non-locking side.)
