Heber stay with the standard rat tail tang. I don't believe you will be
sorry.
Somehow, someone, sometime back got the
mistaken idea that full tang or chiruwa style handles are stronger.
But if done correctly, as the H.I.Kami's do, the rat tail tang
is just as
strong!!!!
The rat tail tang has radiused corners, which are less apt to shear, and they are very substantial and very
strong.
I only have one chiruwa handled khukuri, which was sent to me by a generous H.I.Member here,
that I
really care about although I haven't been out to test it as yet, actually haven't even sharpened it as I've been too busy with personal things lately and so the jury is still out in its case.
I don't know if it is going to vibrate in my hand when chopping as that style handle usually does, but I'm thinking it probably will.
Some people don't notice the vibration or it doesn't bother them.
But for us old farts it does make a difference.
The rat tail tang doesn't set up the vibrations and are much more comfortable to use which is the opinon of most of us here.
And the rat tail tang doesn't shrink away from the tang as the chiruwa handles are prone to do.
The shrunken wood or horn causes a ridge on each side of the steel making for a very uncomfortable grip.
The only way to repair them is to file the steel away until there's once again a smooth junction.
And another thing is that if a rat tail tang khukuri's handle is to big they can be shaped to fit much easier by carefully removeing wood or horn, making the handle more egg shaped with the small part of the oval at the bottom of the handle.
I have had to remove a lot of wood all the way around from my GRS and Super Salyan in order for me to have a better grip with them.
Anytime a handle is too big it's easy to lose your grasp when using the
khukuri.
And I don't have to tell you the danger of a flying khukuri.
I have done the
"Khukuri Dance" a few times and now after carefully testing a large handled khukuri I set it aside until I have time to modify the
handle.
That keeps the Safety Officer and myself happy.
Hope this helps you to make a decision and don't ever let anyone tell you a rat tail tang isn't as strong as a full tang.
The rat tail tang has been used very successfully for centuries.
