- Apr 12, 2009
(...)My question about the diamond spray stems from me wondering if the diamond on leather thing would be a way to cut faster with a strop and avoid the necessity of taking a stone to the knife if it needs more than the black compound.(...)
If the desire is to cut faster in substitution of using a stone, you'd be better off using a substrate other than leather, UNLESS the leather is extremely hard. A harder substrate like wood, or single thickness of paper over wood, will make the bigger difference in speed, AND it'll leave the edge much crisper than if trying to use a more aggressive compound on a softish/forgiving substrate like leather. Trying to get fast cutting from leather usually encourages the user to press into it harder, which will only tend to round off the apex, no matter the compound used.
Leather is at it's best when used at featherlight pressure for final edge cleanup (removing burrs or realigning a very thin rolled edge, basically). If trying to get more aggressive metal removal in lieu of using a stone, the stropping substrate should still be maintained very firm/hard, so you won't round off & dull the edge. More aggressive compounds on leather will just do that faster. Same applies for using sandpaper; a hard backing behind it will make it work more aggressively AND keep the apex crisper, whereas a more forgiving backing like leather tends to round off the apex.
A natural stropping motion will still tend to convex the bevels, even on a harder stropping substrate BTW, if you're still wanting to maintain the convex. The difference will be that the convex will be a bit subtler (thinner) coming off a harder substrate, and the apex will stay crisper. Those are always good things.
David
