i found a machine flat granite block with a steel rod going threw the center, i think he said is was for a precision dial indicator. well where i dial used to go i mounted a round wood rod, 3/4" or so. because the clamps around the steel rod are adjustable i move them up or down to get the angle i am trying for, check it with my cell phone (protactor app) then use two small clamps and clamp the sandpaper in place, thought i was doing pretty good, choose to reprofile to 13 degrees and went threw all those grits (what was werid is this last time i really didnt get much of a burr). thought i was going pretty good, all i had to do was hold the blade prefectly flat and go down the sandpaper, used the sharpie (actually a dry erase marker so i wouldnt screw up the finer and more expensive mirco-mesh sandpaper) and made sure i was removing material from the entire edge. went down to the 12k and then stropped on leather with white rouge, then plaining leather. as it turned out yesterday when i went to place the mirco-bevel at 17 degrees starting at 15 micro honing paper i was not just hitting the very edge but the entire side of the bevel. any ideas on what i am doing wrong? are my primary angle and mirco-bevel to close. the zt was fine as it was, but i can never leave well enough alone. and that knife was what i first used to learn how to use a beltsander on. well the beltsander won and i removed 60% of the blade material. i sent it to Kershaw hoping to be able just to purchase a new blade, maybe even at a discount but they sent it back with a brand new blade (thought it was all black, no markings. also has anyone had a replacement blade that all the lines in the blade where off? if you looked at one side of the blade the top center of the blade (both thickness and dept where different, i thought kershaw maybe placed blades that didnt pass quality control on there warranties, but no after talking to them they said there blades where all black so they could use them in any knife, only thing i didnt understand was i didnt think there was another kershaw/ZT knife that would use the 300 blade) anyways not liking that the beltsander got the best of me, i decided to try again and very carefully thinned the blade enough to make both sides match, there was alot of hand sanding in there though. wrapping everything up, i ended up with a much thinner blade, kind of similar to a large BM flipper i saw. Oh the first reprofile was done with a homemade jig that clamped the blade and a rod. I will try and post some pics. i am diffinitely getting sharper but after all this work i am going to carry it as an after work knife, something scary sharp, profiled down so i could easily shave with it, but not much of a work knife. i am working on getting some pics right now.
