- Aug 30, 2007
So I've decided to get a new folder for camping and work. It needs to be sturdy for both jobs. Normally I wouldn't choose a knife with serrations for camping, but everyday at work I'm having to cut through straps and tiedowns and things like that, so on this knife, the partially serrated blade is going to be a plus. Also, I wanted something that had somewhat of a handguard, either created in the blade or the handle even if its only slightly. It's common here at the shop to be working with a little oil or grease or chain lube on your hands so something to keep you from slipping up onto the blade is a big plus. After looking around at all the normal knife places, these are the two that look best suited for the job. I also considered the CRKT M16 with the double thump thingies, but these two look a little beefier and I want it to be a large folder. I know these two are on two sides of the cost range, but these are the two that fit the riquirements best so far. They are the Boker Armed Forces Tanto Folder II and the Remington Premier Tactical Zulu II Tanto Military. I'd like to know if any of you guys have had any experience with either of these and what you think of them. Also, if you have any suggestions that meet my requirements and are in that $35-$130 range, let me know. Just keep in mind they have to be big, partially serrated, and with some sort of handguard on both sides. I know the Zulu is a straight blade, but it's blade material and grip makes up for it.
Thanks guys.
Thanks guys.
