dantzk8
Basic Member
- Nov 1, 2005
Hi Soap,
You did well. For the A or B options i can't give you a valid opinion as i've never used a Naniwa stone but i would suggest to keep some coherence in your set up line and go for the Shapton 8k. The Shapton grit scale is not the same than the Naniwa's one if i well remember. I don't even try to check as i've got the flu and have yet an headache.
You may be should to experience all the abilities of the Shapton 5k before buying a 8K. More i use the 5k more i can refine my edges. when you hold the blade like if it was a new born bird's feather (hope it makes sense) you can get surprising results. The purchase of a 2k could be more relevant since it's a very good stone which makes a good bridge between the 1k and the 5k and is by its own a very good finish for some kitchen or all around uses.
You can lap any stone upper 1k with the Atoma 400. You can as well use a 1k to lap a 5k and a 5k to lap a 8k. It takes more time but the result is smoother. Higher the grip smoother you want it to be anyway.
Hope it helps, when the Americans will be waked up they will give valuable advices though i don't think to be wrong there.
dantzk.
dantzk.
