- Aug 27, 2004
Steve, I would like to hear your esteemed opinion about BG-42 steel. Many people praise it as a fine edge steel, e. g. Sal Glesser, etc.
My very positive experience with BG-42 comes from Spyderco's CF Military and Buck's 110 custom (red/black Micarta/G-10 combo) and the 532 Year 2000 knife, the Bucks beeing HT by Paul Bos, of course.
Thanks,
Franco
I have high praises for BG42 for the most part but its problematic in several known areas regarding heat treating it right, being rather expensive and I understand now, harder to find too.
I rate it as a finer grained more refined alloy than S30V personally but I can't say I've looked at both that close. I'm just basing that on my experience sharpening both. S30V is a great steel don't take that wrong. I'm certainly not down playing it. Its just a steel I really feel is more appropriate for aggressive toothy 'thicker' edges for strength not highly polished ones. BG42 seems to be able to wear both hats.
As I pointed out earlier though 13C26 AKA Aeb-L is a very small carbide steel and you can make this steel very thin and very highly polished along the apex of the edge as a result. The difference between that and S30V is pretty stark. Lose a carbide in AEB-L and you can't really even feel it and most times have to struggle to see it or in my case you just can't.
BG42 would probably be more popular if it were not so expensive but the double vac heat treat process is supposed to be the other kicker and I guess Mete could cover that a lot more detailed than I could. Heat treat science is not my thing. I think its due to these two things that we only see this steel in limited runs and sometimes things like 1st Production runs.
For what its worth I understand from Ragnar at Ragweed forge that some wood carvers have really taken a shine to 12C27 and I know the Norwegians certainly have also because it can be taken thin and sharp. Being tougher than 13C26 it may be just a viable a steel to chose for the highly polished edge so to me these are the two best candidates for stainless.
Probably a bit more than you wanted but I hope that helps.
STR
