The knife arrived yesterday. Just a couple of notes:
The box is the old style, wood grain cardboard with small brass hinges.
There was some question about the sheath in the 2005 discussion. The sheath is unmarked brown leather and a perfect fit to the molded box insert.
PROTOTYPE is a simple engraving, not gold-colored as it appears in some of the photos.
The handle material is a very smooth and very glossy synthetic. When held at angles in the light, a faint jagged banding is visible. Linen Micarta is my best guess.
The handle scales, right and left, aren't perfectly symmetric as you would expect on a mass-produced factory knife. More similar to some mid-grade custom knives I own.
A knife manufacturing Question: Comparing the pins, this white OT's are much smaller than on the standard 14OT. Would the drilled blade hole normally be the size of the intended pins? My point, if one could see beneath the scales and could determine that the drilled holes are small, that would indicate the knife was purposefully made with small pins, and that the non-standard pins aren't simply the result of an aftermarket assembly?
Of course I'm not knocking off the scales just to find out.
