I’m not an expert by any means but I think it also depends on how the edge is ground when it is profiled at time of manufacture and if they keep it cool while grinding. I’ve had identical knives in s30v and one will chip ease and the other will be tough and never chip. As JBC commented in post #22 on his vantage, mine did as well but after reprofiling mine by hand sharpening and removing the chipped edge it was good then and hasn’t chipped any more but I had to take a lot of metal off to get there.
I wonder if sometimes when they machine grind the new blade if they get in a hurry and get it to hot then quench it making it harder at the very edge there by making it more prone to chipping.
I don’t hear as much about chipping problems in s30v now as 5-7 years ago so maybe they have eliminated or fixed what was causing the chipping. And it might not have been the actual heat treatment and tempering process itself but maybe the grind finishing at the edge. I have worked in a manufacturing plant years ago with 700+ employees and I’ve seen similar things like this happen. After some investigation and adjustments things get straightened out. That’s just my thoughts on it.
I've found Spyderco and Benchmade perform equally well on S30V in real world use, with ZT lagging behind. There's a few Benchmade knives that are outliers in the negative side. The reason why there's not much difference despite Benchmade having a slightly superior HT is all because of geometry. Most Spyderco knives are ground to cut. Benchmade is now making a lot of stuff in S30V that's ground compellingly well, like the Bugout.Unless something is really off, are you really going to notice much of a difference? I mean, unless you're doing elaborate cut testing, a small percentage of variation isn't going to make much practical difference. And even if you tested samples, there is almost certainly some small amount of variation batch to batch.
Outside of the odd really terrible performer that suggests something might be hosed, I doubt it matters much.
