Campbellclanman
Platinum Member
- Mar 10, 2007
Wow - thank you very much Jack! - I cant believe how tidy that Joseph Rodgers is for the date of manufacture!!
Well folks, this is the time when those of us who believe in "one blade per spring" are shaking are heads sayin', "what in the heck is you afeared of?" The only time there is extreme stress on a spring is when you got a blade on each end and you tweak both ends of the spring at once.
I'm still not certain that such punishment will weaken a spring, but I can understand that you might flat out break it.
> I then decided to just leave those two blades at half open for a couple of months. After three months there was no change. I just opened them back to the half stops and put it back into the drawer at work. Reading this I remembered it and pulled it out of the back of the drawer. It is still a 9+ on the pull scale after about 2+ years.
You are not doing it right.
You need to open the blade NOT to a half stop, so the spring is raised above the frame. Half stops dont put any more tension on the spring than the fully open, or the fully closed position.
IF your goal is to put extra tension on the spring, hoping it will relax a bit, it needs to stick up like this
or like this:
but not like this
> the knife does not have the Half stops
great info, so, youre telling us that after 2 years of being held under tension, the springs did not relax.. on a GEC.
Conversely we have input from T. Erdelyi
"I still have many older knives that just don't have the snap of a new, younger knife"
and
"you opened the blades on your beloved Stockman or Half Congress to half opened and you didn't find this thread till it was too late, so now your beloved knife opens and closes with the authority a grade school Crossing Guard."
with all due respect, an old knife with a weak spring, does not to me mean it was kept open, and as you can see, a GEC does not relax its spring, by being kept open for 2 years.
But I still dont recommend opening 2 blades at the same time, on opposite ends of the same spring, with no half stops.
I only do it for a quick pic, I cringe more when I hear of people here leaving the blades half open to soften the springs/pull.
Pete
